11 years agoError while debugging using system-console
Hi, I am trying to debug a design containing Nios II on a Stratix V FPGA. When debugging with system-console, while trying to do a memory read, i get the following error : % master_read_me...
11 years agoI have not used system console with NIOs. However, just to share experience using xcvr toolkit which is running on system console as well. You might also want to verify if the system console has been successfully linked to your design before doing the read/write.
