Error while creating a Memory Initialization file in Quartus
- 4 years ago
Yup, you can use the format given online. However, the format you used was wrong, you should not include comma in the content. I'm able to add this .mif file after I had removed all of the comma.
Hi Ean,
Thanks for replying for all my queries, I would like to bring your kind notice that i was able to create the .MIF file for the same program mentioned above with 45 datas but i could not create a .mif file for the above mentioned code with more data's. Moreover i went through the addressing of the .MIF file i created the file in that format but could not create, herewith i attach the snap shot of the addressing that is given in online.
- YEan4 years ago
Contributor
