12 years agoerror while compiling rom in quartus ii 11.0 version
I am karthik ameture in quartus. I am trying to compile a quartus project. However I get an error while compiling the ROM component (generated via megafunction wizard). The error is as below :-
Error: MGL_INTERNAL_ERROR: Parameter altsyncram|WIDTH_A has no default value and has not been assigned any value. CAUSE : An attempt was made to access the value of a parameter which has no default, and has not been assigned a value. All parameters should have a default value, or, if the parameter is a required parameter, an assignment should be made. ACTION : Specify a value for the parameter or if the parameter is an optional parameter, specify a default value. Do you know what exactly is the problem ? Please help us with this. Thanks, regards karthik
