13 years agoError when generating hardware from .aoco file
I am trying to synthesize a kernel for a nallatech 385 board (pcie385n_d5) using the OpenCL toolchain 13.0. I am using the two step approach with the first step generating the .aoco file and the next one compiling it into a .aocx executable.
For the kernel I am trying to synthesize, I keep getting an error in the second step, i.e. going from .aoco to .aocx. I have attached an excerpt from from the log after the first reported error below. Also, the FPGA utilization is <40%, so I think this can't be caused by the design's size (if that's possibility) Any clue what might be the cause here? The closest information I could find was an issue with QuartusII 12.1 toolchain for Cyclone devices [Cannot post the link to it due to forum restrictions]. Have you faced a similar issue? Excerpt from the log: --- Quote Start --- Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info_body.cpp, Line: 2918 node_index >= 0 && node_index < static_cast<int>(m_place_block_list.size()) Stack Trace: 0xe3d9f: DYGR_PLACE_INFO_BODY::get_place_block(unsigned int) const + 0x9f (ddb_dygr) 0xeb5b3: DYGR_DIE_INFO_BODY::get_location(unsigned int, DEV_LOCATION&) const + 0xf3 (ddb_dygr) 0x95c1b: QTK_RCF_UTIL_IMPL::cache_constrained_iterms() + 0x146d (db_qtk) 0x96d91: QTK_RCF_UTIL_IMPL::QTK_RCF_UTIL_IMPL(CDB_ATOM_NETLIST*, RCF_INTERFACE_WRAPPER*, bool) + 0x11f (db_qtk) 0x96e47: QTK_RCF_UTIL::QTK_RCF_UTIL(CDB_ATOM_NETLIST*, RCF_INTERFACE_WRAPPER*, bool) + 0x55 (db_qtk) 0x7f700: FITCC_QIC_UTILITY::get_rcf_util(bool) + 0xd0 (fitter_fitcc) 0x1264d8: FITCC_INCREMENTAL_UTILITY_IMPL::create_postfit_rcf() + 0x118 (fitter_fitcc) 0x4c68a: FSV_EXPERT::fitter_preparation_post_fpp(bool) + 0x98a (fitter_fsv) 0x4da3f: FSV_EXPERT::fitter_preparation() + 0x5f (fitter_fsv) 0x404c9: FSV_EXPERT_BASE::fitter_preparation() const + 0x6e9 (fitter_fsv) 0x42597: FSV_EXPERT_BASE::invoke_fitter() const + 0x847 (fitter_fsv) 0x3cdee: fsv_execute + 0x28e (fitter_fsv) 0x2c8b2: fmain_start(CMP_FACADE*) + 0x562 (fitter_fmain) 0x1a640: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x150 (comp_qfit_legacy_flow) 0x15680: QFIT_FRAMEWORK::execute() + 0x2a0 (comp_qfit_legacy_flow) 0x24f81: qfit_legacy_flow_run_legacy_fitter_flow + 0x1a1 (comp_qfit_legacy_flow) 0x2e8f6: TclInvokeStringCommand + 0x76 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x34310: TclEvalEx + 0x4f0 (tcl8.5) 0x34d13: TclEvalObjEx + 0x393 (tcl8.5) 0x3ac31: Tcl_EvalObjCmd + 0x91 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x73abf: TclExecuteByteCode + 0x151f (tcl8.5) 0xb5bc7: TclObjInterpProcCore + 0x107 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x73abf: TclExecuteByteCode + 0x151f (tcl8.5) 0xb5bc7: TclObjInterpProcCore + 0x107 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x34310: TclEvalEx + 0x4f0 (tcl8.5) 0x98c70: Tcl_FSEvalFileEx + 0x230 (tcl8.5) 0x98d6e: Tcl_EvalFile + 0x2e (tcl8.5) 0x101a2: qexe_evaluate_tcl_script(char const*) + 0x43b (comp_qexe) 0x13c5f: qexe_do_tcl(QEXE_FRAMEWORK*, char const*, char const*, _Dinkum_std::list<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > > const&, bool, bool) + 0x4e9 (comp_qexe) 0x14ab8: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, _Dinkum_std::list<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >*, bool) + 0x51d (comp_qexe) 0x37756: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, _Dinkum_std::list<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >*, bool) + 0x7b1 (comp_qcu) 0x17aaf: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x403 (comp_qexe) 0x98b9: qfit2_main(int, char const**) + 0xa9 (quartus_fit) 0x361a0: msg_main_thread(void*) + 0x10 (ccl_msg) 0x7fac: thr_final_wrapper + 0xc (ccl_thr) 0x36d45: msg_thread_wrapper(void* (*)(void*), void*) + 0x5b (ccl_msg) 0x19135: mem_thread_wrapper(void* (*)(void*), void*) + 0xc5 (quartus_fit) 0xf408: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err) 0x838c: thr_thread_wrapper + 0x15 (ccl_thr) 0x48f37: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x96 (ccl_msg) 0x1ecdd: __libc_start_main + 0xfd (c.so.6) 0x9149: __gxx_personality_v0 + 0x309 (quartus_fit) End-trace Error: Flow compile (for project /home/kgeorgen/ocl/mreduce1/mreduce1/top) was not successful Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last. --- Quote End ---
