12 years agoWere you an early access customer by any chance (i.e. using the tools before the 13.0 release)? I've seen this sort of thing happen when a version of Quartus other than 13.0 is being referenced by QUARTUS_ROOTDIR. If you are an early adapter I would try out 'which quartus' and 'which aoc' to make sure your enviornment is pointing at just to make sure older versions of the tools are not getting called.
