CPaul
7 years agoError: (vsim-3732) The following component port is not on the entity: # IR31_to_26
Hello, I am trying to create a testbench for a mips processor in VHDL. It compiles fine in quartus and in modelsim but when I try to start the simulation I get this error. * Error: (vsim-3732) D:/Q...
CPaul
7 years agoI am a bit confused on how to actually read the transcript for what the compile order of my files should be. is it possible you could tell me what files you included in the compilation and what order they were in on modelsim?
AnandRaj_S_Intel
7 years agoHi @CPaul ,
Order "decoder7seg.vhd" "memory.vhd" "mux2x1.vhd" "mux2x1_5bit.vhd" "mux4x1.vhd" "ram_256.vhd" "reg32.vhd" "register_file.vhd" "sign_extend.vhd" "alu_control.vhd" "alu_ns1.vhd" "controller.vhd""datapath.vhd" which worked. copy past it in file name under compile source file tab.
For error which you have you have to compile controller .vhd and run simulation.
Anand
