8 years agoError: (vsim-3033) Instantiation of 'alt_dual_boot_avmm' failed.
Hi there I am have a severe and persistent problem with an attempt to simulate a MAX10 Qsys (platform designer) system in Modelsim. Everytime I try to run an RTL simulation from the synthesized...
8 years agoI'm presuming you have generated the system in Platform Designer or performed at least synthesis to have the system design files generated.
Also, you mention ModelSim. Are you using ModelSim-Intel FPGA edition or stand-alone ModelSim (SE or PE)? If you are using stand-alone ModelSim, you have to set up the IP simulation models to get compiled in the tool. The Intel edition has all this pre-compiled.
