12 years agoHi there,
(sry if i should have opened a new thread for this) I got the same problem when I run the command aocl flash hello_world.aocx I use Linux (centOS) which runs on a remote server. Do you think this is the same problem with the bridge and how do I turn it on using this command? Thanks for any help p.s.: i found a thread where the solution was that : "i bungled connecting the break-out board to the fpga. i have now done it properly and aocl flash works like a chram." . What is a break-out board? What should I do - I do not understand the solution...
