14 years ago --- Quote Start --- what type of file is "myfile"? it sounds like the command is expecting a SFL/PFL flash loader image on the FPGA but its not there. the GUI is loading the expected SFL which is why the command will work after running the GUI --- Quote End --- Thanx for answering. myfile is a .JIC file. Do you think that there is a switch in the command line functions that will make this work without the GUI?
