18 years agoError undefined entity
Hi QuartusII-experts
Error message: Error: Node instance "u_tone_finder_top" instantiates undefined entity "tone_finder" Relevant VHDL-code in the file, where "tone_finder" is used (which is not top-level entity): LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE IEEE.numeric_std.ALL; USE IEEE.std_logic_arith.ALL; USE IEEE.std_logic_unsigned.ALL; USE work.tone_finder_pkg.tone_finder; ... -- component for tone finder project u_tone_finder_top : tone_finder PORT MAP ( -- System signal aclr => rst_delayed, -- 7-Segment Display ouv8_hex_display => hex_display0_intern, -- System signal Clock => r_clk_n_pulses_48k.clk, -- Control Signals iuv18_toggle_switch => toggle_switch_in, -- Audio Codec Interface isv16_audio_data => sv16_left_audio_data_in, osv16_tone_data => sv16_audio_data_out ); ... Relevant VHDL-code in "tone_finder.vhd": LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE work.de2_io_definitions_pkg.ALL; USE work.clock_gen_1536k_pkg.ALL; PACKAGE tone_finder_pkg IS COMPONENT tone_finder IS PORT ( -- System signal aclr : IN std_logic; -- 7-Segment Display ouv8_hex_display : OUT std_logic_vector(7 DOWNTO 0); Clock : IN std_logic; -- Control Signals iuv18_toggle_switch : IN std_logic_vector(17 DOWNTO 0); -- Audio Codec Interface isv16_audio_data : IN std_logic_vector(15 DOWNTO 0); osv16_tone_data : OUT std_logic_vector(15 DOWNTO 0) ); END COMPONENT tone_finder; END PACKAGE tone_finder_pkg; ----------------------------------------------------------------------- --altera translate_off library IEEE; use IEEE.std_logic_1164.ALL; use IEEE.NUMERIC_STD.ALL; use IEEE.std_logic_1164.ALL; USE work.de2_io_definitions_pkg.ALL; USE work.clock_gen_1536k_pkg.ALL; entity tone_finder is port ( aclr : in std_logic; ouv8_hex_display : out std_logic_vector(7 downto 0); Clock : in std_logic; iuv18_toggle_switch : in std_logic_vector(17 downto 0); isv16_audio_data : in std_logic_vector(15 downto 0); osv16_tone_data : out std_logic_vector(15 downto 0) ); end entity tone_finder; architecture rtl of tone_finder is component tone_finder_top_GN7422 is port ( aclr : in std_logic; ouv8_hex_display : out std_logic_vector(8-1 downto 0); Clock : in std_logic; iuv18_toggle_switch : in std_logic_vector(18-1 downto 0); isv16_audio_data : in std_logic_vector(16-1 downto 0); osv16_tone_data : out std_logic_vector(16-1 downto 0) ); end component tone_finder_top_GN7422; begin tone_finder_top_GN7422_0: if true generate inst_tone_finder_top_GN7422_0: tone_finder_top_GN7422 port map(aclr => aclr, ouv8_hex_display => ouv8_hex_display, Clock => Clock, iuv18_toggle_switch => iuv18_toggle_switch, isv16_audio_data => isv16_audio_data, osv16_tone_data => osv16_tone_data); end generate; end architecture rtl; I included the files "tone_finder.vhd" in QuartusII-project (Assignments --> Settings --> Files), but get still the error message above. Can anybody help me!!! Thank's a lot!!! (I'm wasted nearly 10 hours by now). Reto
