11 years agoError trying to generate encrypted FPGA configuration file
Hi Folks,
I am trying to encrypt the FPGA configuration file and I am getting an error. I am using Quartus II 14.0. I referring to the document AN-556 titled: "Using the Design Security Features in Altera FPGAs" for the procedures to generate an encrypted FPGA configuration file and the key programming file. Here is the error message: [pavan@kt-hw1 run1]$ /home/tools/altera/14.0/quartus/bin/quartus_cpf --64bit -c -k ./output_files/keyfile:key1 output_files/zorya_top.sof output_files/zorya_top.rbf Info: ******************************************************************* Info: Running Quartus II 64-Bit Convert_programming_file Info: Version 14.0.0 Build 200 06/17/2014 SJ Full Version Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus II License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Apr 7 09:03:13 2015 Info: Command: quartus_cpf --64bit -c -k ./output_files/keyfile:key1 output_files/zorya_top.sof output_files/zorya_top.rbf Error: Quartus II 64-Bit Convert_programming_file was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 361 megabytes Error: Processing ended: Tue Apr 7 09:03:14 2015 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:02 [pavan@kt-hw1 run1]$ Any ideas what might be wrong? I noticed a line in the app note (AN-556) stating: "To enable the design security feature, you can obtain a license file from Altera Technical Support." Is this true? Do I need a special license to enable the Quartus II SW to generate encrypted configuration files in Quartus II 14.0? If I need an additional license, what is the name of the license? Thanks, jp1 Reply
If u are using subscription edition,the encryption license shud already bundled together with ur Quartus.try check ur license file..see if u can find 'FEATURE quartus_nonvolatile_encryption'.
