8 years agoError to add HEX file in Convert Program File tool
Hi, I am trying to generate EPCS64 .pof file with a .sof and two .hex file. But when i add any hex file error comes "Data in HEX file overlaps between data blocks at address 8 and address 0 ". ...
8 years agoHello Sir,
I have Quartus Prime 16.1 standard Edition. I found "Read or Write Hexadecimal(.hex) Files using byte addressing" in Setting-> Compiler Process Settings-> More settings. I tried with all three settings, on, off & use global setting, but still the same problem. Thanks
