8 years agoError to add HEX file in Convert Program File tool
Hi, I am trying to generate EPCS64 .pof file with a .sof and two .hex file. But when i add any hex file error comes "Data in HEX file overlaps between data blocks at address 8 and address 0 ". ...
8 years agoHi Piyush Mahajan,
Add your Hex file in project directory (Should be visible in files window) 1. Go to file ->Memory Files->Hex Decimal(Intel Format) File->select ->Ok 2.Number of words and word size Tab will open ->Let it be default values dont change any values. 3.New hex file will be opened in your 4. go to tools->options->Memory Editor->Uncheck the option Read or write Hexadecimal Files (.hex) using byte addressing (Intel format)->Ok 5.Open you hex file one after the other by double clicking it (from project navigator->files)->hex file word size tab will be opened ->click ok 6.Again go to tools->options->Memory Editor->check the option Read or write Hexadecimal Files (.hex) using byte addressing (Intel format)->Ok 7. do same for another hex file from step -3. Now generate the .pof file. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- giomate5 years ago
I have this similar error at converting to .pof files actually , i had load and unload many times the .hex file and check and uncheck the "Read" even more. But it is still comming out the same error "Data in HEX File overlaps between data blocks at address 8 and address 0"
Im ussing Quartus Prime Version 20.1.0 Build 711 06/05/2020 SJ lite Edition,
I really appreciate any comment or suggestion
