8 years agoError to add HEX file in Convert Program File tool
Hi, I am trying to generate EPCS64 .pof file with a .sof and two .hex file. But when i add any hex file error comes "Data in HEX file overlaps between data blocks at address 8 and address 0 ". ...
8 years agoHi Piyush Mahajan,
Add your Hex file in project directory (Should be visible in files window) 1. Go to file ->Memory Files->Hex Decimal(Intel Format) File->select ->Ok 2.Number of words and word size Tab will open ->Let it be default values dont change any values. 3.New hex file will be opened in your 4. go to tools->options->Memory Editor->Uncheck the option Read or write Hexadecimal Files (.hex) using byte addressing (Intel format)->Ok 5.Open you hex file one after the other by double clicking it (from project navigator->files)->hex file word size tab will be opened ->click ok 6.Again go to tools->options->Memory Editor->check the option Read or write Hexadecimal Files (.hex) using byte addressing (Intel format)->Ok 7. do same for another hex file from step -3. Now generate the .pof file. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
