8 years agoError to add HEX file in Convert Program File tool
Hi, I am trying to generate EPCS64 .pof file with a .sof and two .hex file. But when i add any hex file error comes "Data in HEX file overlaps between data blocks at address 8 and address 0 ". ...
8 years agoThank you sir for your quick reply.
I am using Quartus 16.1 Prime Edition & unable to find Memory Editor in tool menu. Actually i have a Qsys in which two NIOS-II CPUs with their Independent memory (OCRAM) (No shared memory). when i generate hex file by using mem_init_generate utility & generate final .pof file by adding this hex file in setting menu, i found that some time cpus are not initialize correctly & pause execution. Also not able to Debug. So i thought there may be issue to add hex file, that's why i would like to check by adding sof with hex file using Convert File Utility. Please give any suggestion.... waiting for your reply.... Thanks, Piyush Mahajan
