Error: System Console error in EMI toolkit for QDR 2
Greeting,
Thank you for posting in Intel Community.
Have you take a look on this Knowledge Base Article (KDB) : https://www.intel.com/content/www/us/en/support/programmable/articles/000076755.html
Which Quartus version that you used?
Adzim
Once a programming .sof file is linked through the "Link Project to Device" step in the EMIF Toolkit, and then unlinked through the "Unlink Project from Device" step, the same programming .sof file can't be re-linked through the "Link Project to Device" step again. If this is required, you will need to close the EMIF Toolkit and then re-open it.
I have done this procedure,then also it is showing the same error.
I have used Quartus 16 and Quartus Prime 17 version.Whether IP cores are updated in Quartus 16 and 17 version?
