11 years agoError: s0: Cannot find sequencer/sequencer.elf
Hello, I'm using the latest Quarts and AOCL combination (v15.0.1) on Linux (RHELv6). I have been observing an error with the aoc compiler when compiling HDL. aoc -c foo.cl works fine, but aoc f...
11 years agoThat's actually something strange that I still don't understand since it should not be enabled by default. Perhaps, the problem disappeared because I simply logged off and in to the machine, and the ssh X forwarding may not be relevant. In fact, I observed the same problem again even with 'ssh -x', but again it is "fixed" with relogin. Anyway, now I seem to be able to work around the problem.
