10 years agoError reading Quartus II Settings File
I'm not sure what happen everything was working fine on my pc I was able to work on project that were created using Quartus v15 on Quartus v13 However, suddenly I started to have this problem the ...
10 years agoIf you generate the project in Q15 then there are likely to be settings that earlier versions do not understand.
Just comment out the line that it doesnt like and see if it still works. (the .qsf file is just a tcl file, so comment it out with# ) But there may be a reason that setting exists.
