10 years agoError pre-loading RAM on MAX10
I'm trying to pre-load a 2-port RAM IP on a MAX10 10M08SAE144C8GES. It should support pre-loading since it is an SA version. When I get to assembling I get this error in Quartus Prime: Error ...
10 years agoWhich configuration mode is selected for your project?
Under 'Assignments' -> 'Device', select 'Device and Pin Options'. Under the 'Configuration' tab ensure the 'Configuration mode' is set to a mode 'with Memory Initialization'. Cheers, Alex
