- TRoux
The right access of the libxerces-c-3.2.so delivered with Quartus 19.1 are wrong. To fix it:
chmod 555 $QUARTUS_ROOTDIR/linux64/libxerces-c-3.2.so
Same issue with libpython3.so:
chmod 555 $QUARTUS_ROOTDIR/linux64/libpython3.so
- MPetr24
Same here, which distro are you using? Mine is: Red Hat Enterprise Linux Workstation release 7.4 (Maipo), which should be fully supported as far as I know...
- mvemp
I am using Ubuntu 16.04.
- Abe
Download and install the following package and then try:
https://rpmfind.net/linux/rpm2html/search.php?query=libxerces-c-3.2.so()(64bit)
Make sure you choose the right package for the Distro.
- MPetr24
Thank you,
I was for downloading the package when I realized that there isn't any package for my distro (Red Hat Enterprise Linux Workstation release 7.4).
I then tried to look inside Red Hat repository and found that only version 3.1.1-9 of the package is available...
Any suggestion?
Thank you
- Abe
You can try the following:
cd ~/opt wget http://apache.forsale.plus//xerces/c/3/sources/xerces-c-3.2.0.tar.gz tar -xzvf xerces-c-3.2.0.tar.gz mkdir -p xerces-c-3.2.0-build cd xerces-c-3.2.0-build cmake -DCMAKE_INSTALL_PREFIX=~/opt ../xerces-c-3.2.0 make make installOr just try installing the package for Fedora and see if it helps. This should not cause issues as this package is mostly used by Quartus alone.
- MPetr24
fixed!
Thank you for your help!
- KennyT_altera
Hi, can provide the full error message? And the OS that you were using? I want to document this. Thanks - TRoux
The message was "quartus: error while loading shared libraries: libxerces-c-3.2.so: cannot open shared object file: No such file or directory".
I think that you get this message when you install Quartus as root and try to launch Quartus 19.1 as a "simple user" which is not in the same group as root.
I'm using CentOS Linux release 7.6.1810 (Core).
Thierry
- KennyT_altera
