18 years agoError message
I do not understand why I am getting the error message for the code below....
Error (10818): Netlist error at up_dwn_counter.vhd(61): can't infer register for d_o[0] because it does not hold its value outside the clock edge Thank you in advance!! Bojan ************************* library ieee; use ieee.std_logic_1164.all; --use ieee.numeric_std.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity up_dwn_counter is port ( rst : in bit; clk : in bit; --uartclk : out bit; u_d, cl :in bit; d_o : out std_logic_vector (31 downto 0) ); end up_dwn_counter; architecture counter of up_dwn_counter is shared variable counter: std_logic_vector (31 downto 0);-- :="00000000000000000000000000000000"; begin count: process (cl, rst, u_d) begin if (rst'event and rst = '1') -- This is supposed to check for rising edge of rst then d_o <= "00000000000000000000000000000000"; counter:="00000000000000000000000000000000"; if (cl'event and cl = '1') -- This is supposed to check for rising edge of cl then if (u_d = '1') then counter := counter + "1"; else counter := counter - "1"; end if; else if (cl'event and cl = '0')-- This is supposed to check for falling edge of cl then if (u_d = '0') then counter := counter - '1'; else counter := counter + '1'; end if; end if; d_o <= counter; -- to_StdLogicVector(counter);-- (31 downto 0); end if; -- clockevent end if; -- rst_event end process; end; -- end of architecture "counter"
