11 years agoError Message Quartus Web don't support BEMICROMAX10
Hello I have problem with quartus web edition. I bought BEMICROMAX10 board from ARROW because I thought i can use that board with free quartus but when i'm trying compile example project i have ...
11 years ago --- Quote Start --- The error message indicates a problem with your web license setup ... which since the web version does not use a license is a problem :) I have 14.1.0 web edition installed. I created a test design, selected the device mentioned in the log above, created a top-level design using a basic shift register template (from Quartus' VHDL templates), synthesized it, and it worked fine. I have uploaded a couple of screen shots. You could try re-installing your web edition ... Cheers, Dave --- Quote End --- Thank your for help. I solve the problem. On this computer previously was installed quartus 10 with subsciption. And old license file was on C drive
