JKing29
7 years agoError: "make: quartus_map: Command not found"
I'm trying to compile a quartus project using a makefile, getting this error.Can't find much help about quartus_map, but I've downloaded and added it to my path. To my understanding this should work. Output from echo $PATH:
Thanks for any help
1 Reply
- GuaBin_N_Intel
Contributor
Not quite know about what your makefile is and how it executes from. May need you elaborate more. Did you manage to run quartus_map at NIOS command shell?
