MFort6
6 years agoerror in .VWF if using IP
Hi below is my code, it simulated perfectly but when i want to check the outputs using the .VWF file i am getting the following errors which are listed at the bottom. i am using Altera Stratix® V GX...
RichardT_altera
6 years agoBased on the errors, it seems that you might be missing some libraries or simulation models.
You will need to check and compile the design files before running the simulation.
- RichardT_altera6 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
