14 years agoError in SOPC : The given combination of PLL input and output cannot be synthesized.
hi,
I just aquired a new PC and I'm trying to generate a SOPC design which was previously generated on another PC. However, when I open the SOPC design on the new PC, there is a error message present : Error: <altmemddr>: The given combination of PLL input and output cannot be synthesized. I tried changing the input/output combination, but that did'nt help. I find this strange, since the QII versions are exactly the same on both PC's (version 11.1sp2). Even when I try adding a new instance of the DDR2 SDRAM controller with ALTMEMPHY the error message is present. Can anyone provide some help out with this issue ?
