12 years ago --- Quote Start --- where Lr0,Lr1,Lr2 are defined as uint4 variables, ld0,ld1,ld2 are char variables with members s0,s1,s2 and s3, so I was using it like --- Quote End --- I'm confused a bit, you're saying that ld0, ld1, and ld2 have members, i.e., they're char4? Or are they char? If they're char4, then you should post-fix ".word" to them also.
