Error in generating EMIF IP example design with tcl
hi all,
The following lines i have taken from emif ip example design user guide
"To create a compilable project, you must run the quartus_sh -t make_qii_design.tcl script in the destination directory.
To create a simulation project, you must run the quartus_sh -t make_sim_design.tcl script in the destination directory."
but while running the command in tcl window i got the following..
Error:invalid command name "quartus_sh"
Error: while executing
Error:"unknown_original quartus_sh -t make_qii_design.tcl"
Error: ("eval" body line 1)
Error: invoked from within
Error:"eval unknown_original $cmd $args"
Error: (procedure "::unknown" line 7)
Error:"quartus_sh -t make_qii_design.tcl"
kindly help me to get this.
MuralikumarM
Hi
Tcl window in the Quartus does not recognize the quartus_sh command. If you use the Quartus Windows version please open a Nios2 command shell and type "quartus_sh -t make_qii_design.tcl" then it should work
1 Reply
- yoichiK_altera
Contributor
Hi
