13 years ago --- Quote Start --- I mean by "fail" that the outputs of the design aren't true. --- Quote End --- this doesn't really help... --- Quote Start --- On Modelsim, in case of CYCLONE, pre-compiled simulation library of CYCLONE was required, in case of CYCLONEII, pre-compiled simulation library of CYCLONEII was required, and in case of CYCLONEIII, two pre-compiled simulation libraries were required (CYCLONEIII,ALTERA). For each case, i used the .vho and .sdo file of it. --- Quote End --- Do you have different warnings from Modelsim before it starts the simulation, when running for the Cyclone III? Warnings such as "Warning: No default binding for component: xxx" can meen it didn't find the correct component to instantiate from the libraries it has, and it will most probably give wrong simulation results.
