13 years ago --- Quote Start --- When the design is synthesized and the FPGA target is either CYCLONE or CYCLONEII, the gate-level timing simulation operates properly. But, when the same design is synthesized and the target FPGA is CYCLONEIII, the gate-level timing simulation doesn't work properly. Is there a reason for this ? Thanks :) --- Quote End --- The testbench does not set up the inputs to meet the timing requirements. Kevin Jennings
