11 years agoError during programming using a batch file
Hi, I have a chain of devices which is programmed successfully using the programmer GUI but the programming fails while I'm using a batch file which our team wrote. The chain is comprised of dev...
11 years agoI don't know what the changes will be, except that the newer version will support the newer parts. It's possible that, in adding new families/devices, the database/index of these parts has an error in it. However, I'm only guessing.
Cheers, Alex
