11 years agoError during programming using a batch file
Hi, I have a chain of devices which is programmed successfully using the programmer GUI but the programming fails while I'm using a batch file which our team wrote. The chain is comprised of dev...
11 years agoAlex thanks for your reply, I have noticed that the batch file works fine with Quartus programmer 6.0 (even though Altera declares that it isn't supported on windows 7). Do you have any idea for that difference between the programmer versions?
