10 years agoError DS-5 install
Hello, I'm having trouble installing the DS-5 on RHEL 6.7, I can not resolve this dependency:
--- Running installation platform requirement checks /tmp/inst_temp.2994/dependency_check_linux-x86_64.sh: line 13: 3087 Segmentation fault (core dumped) ${SCRIPT_DIR}/library_checker_$2 $1 2> /dev/null Running dependency check [failed] *** WARNING *** One or more of the DS-5 system dependencies are not installed, see below for a list of the missing libraries. libGL.so.1 (32-bit) We recommend you install the missing dependencies, otherwise the programs will not run correctly. For further information see the DS-5 readme. When I run the embedded_command_shell.sh, I have: WARNING: DS-5 install not detected. SoC EDS may not function correctly without a DS-5 install. ------------------------------------------------ Altera Embedded Command Shell Version 15.1.1 [Build 60] ------------------------------------------------ Someone had the same problem? Or you can show me another OS? Regards, PauloNo RepliesBe the first to reply
