description This error may be seen when starting the Quartus® II Megawizard™ Plug in Manager. This error may be seen if you do not have sufficient physical memory in your computer. For detai...
--- Quote Start --- You should try to contact Altera via a support request. --- Quote End --- Asked, they will not say! Do not believe you can ask to see.
