13 years ago --- Quote Start --- The memory requirements are here (http://www.altera.com/literature/rn/rn_qts_dev_support.pdf). What FPGA are you targetting? Do you have a lot of programs running? A big antivirus? Anything that could eat up memory? --- Quote End --- Currently using Cyclone II EP2C8 & EP2C70(Install DDR2 IP Core) Why computer memory upgrade 4GB can not be used? Why Kaspersky&360 removed will be able to use?(Note:Kaspersky&360 takes the 20MB memory:mad:) After why deletes Kaspersky&360. the computer remains 1GB all to be able to use?:mad:
