gbarc2
7 years agoError compiling hello_world.cl with aoc
I recently installed the Intel OpenCL SDK toolchain for FPGA on a Linux system by following the guide provided here https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-...
HRZ
7 years ago"Processor" refers to the host processor in YY's reply, not the FPGA. You need 32 to 64 GB of host memory for one instance of Arria 10 placement and routing. How much memory is installed on the machine that you are using for placement and routing?
Also the "quartus_sh_compile" log you posted earlier does NOT show any errors and the process has finished successfully. Can you post the log for a compilation that failed?
- JMilt17 years ago
We have 96GB of memory on the host processor.
As gbarc2 said, for the failing compilations, the only line in the quartus_sh_compile.log for the failing compilation is:
ERROR: packager tool failed to run. Check installation. Aborting compilation!
