15 years agoError: Can't run SignalTap II Logic Analyzer
I have met some questions when I used Signal Tap Ⅱ Logic Analyzer to debug program. When I changed sampling signal, and recompiled my project, the soft of quartus suggest an error that is “Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed in the device”, and The toolbar of instance manager displayed “JTAG communication error” and instance status displayed “not compatible with the device in Signal Tap Ⅱ Logic Analyzer window.
When I searched solutions I find a similar question: solution id: rd05232010_914 last modified: Jul 20, 2010 product category: Design Software product area: On-Chip Debug product sub-area: SignalTap II problem Why do I get errors when running the alt_signaltap_run function in MATLAB? solution When using the MATLAB executable (MEX) function alt_signaltap_run in MATLAB to acquire data from the SignalTap™ II Logic Analyzer, your SignalTap II configuration file (.stp) is cached to improve repetitive acquisition performance. If the .stp file is changed, it may not be reloaded when the alt_signaltap_run function is called multiple times. This may prevent the acquisition of data based on the new trigger specification and produce the following errors: Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed in the device Error: Can't find the instance. Download a design with SRAM Object File containing this instance. Error: JTAG communication error. Check hardware setup. To work around this problem, clear the cache so that the .stp file is reloaded the next time the alt_signaltap_run function is called. To do this, run the following command in MATLAB: clear alt_signaltap_run Expectinh your help!
