Error: Can't launch QuestaSim Simulation software
- 4 years ago
Ok, I solved downloading the missing file from:
and then launching
C:\WINDOWS\system32>sfc /scannow
from command prompt.
Windows is strange when you're a stranger...
Sounds good, hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
Hello AR_A_Intel,
I am having a similar problem trying to invoke the Questa simulator in Quartus 21.1. Here is the error message I get:
"Can't launch the Questa Intel FPGA software -- the path to the location of the executables for the Questa Intel FPGA software were not specified or the executables were not found at the specified path."
My Questa Intel FPGA path is set to: "c:/intelFPGA_lite/21.1/questa_fse". I also tried "c:/intelFPGA_lite/21.1" with no luck.
Am I missing the file mentioned in the above discussion?
Thank you for any help you can provide for this issue.
Greg
