15 years ago
Error: Can't find name for bus
Hi Guys,
I have a question concerning my Block-Editor-Project, which I have been working on. I have to connect a counter, which has a 20 bit Output to a lmp_compare-Symbol, which has a 20 bit Input.
Somehow Quartus complains while synthesis and gives me the error message:
If I click on the error message it shows the bus line I mentioned above. I always thought that, this bus line didn't need a name. I named the bus also, but that doesn't cure the problem.
Would be really great, if someone of you could give me a useful hint.
Thanks a lot!
    --- Quote Start ---
    Hi Guys,
    Thanks a lot!
    --- Quote End ---
    as far as I know you have to assign a name to the bus in your schematic.
    Select the bus, right mouse click, choose properties and add a name like a[3..0].
    Kind regards
    GPK
    Sorry for bothering you. I found the mistake. Guess, I was a bit tired yesterday, when i didn't see that I assigned two different names to the same busline.
    Have a nice day!
