9 years agoError: Cannot find sequences/sequencer.elf
Hi All!
I'm trying to compile for the reference stratix 5 board (s5_ref) using altera's AOC 17.0, but I get the following error:
2017.06.27.15:07:17 Error: s0: Cannot find sequencer/sequencer.elf
2017.06.27.15:07:17 Error: s0: An error occurred
2017.06.27.15:07:17 Error: Generation stopped, 303 or more modules remaining
2017.06.27.15:07:19 Error: qsys-generate failed with exit code 1: 3 Errors, 43 Warnings
Error: ip-generate FAILED.
Attached is the log (the log is from 16.0, but 17.0 gives the same error). Does anyone know how to fix this? Thanks in advance!4 Replies
Already answered her:
https://alteraforum.com/forum/showthread.php?t=49027 Close your screen, log out and then log back in and open a new one. - Altera_Forum
--- Quote Start --- Already answered her: https://alteraforum.com/forum/showthread.php?t=49027 Close your screen, log out and then log back in and open a new one. --- Quote End --- Thanks for the suggestion, but sadly that does not work. The bug is persistent and does not disappear if I restart login and the screen. Any other ideas? - Altera_Forum
You have X11 forwarding disabled, right? If you can reliably reproduce the issue, open a support request with Altera. Maybe this would allow them to finally fix this issue once and for all.
P.S. I also previously encountered this issue when I was compiling kernels using makefiles that "exported" variables and called other makefiles to run the kernel compilation command. if this is what you are doing, avoid it. - Altera_Forum
Thanks! Yeah X11 forwarding is disabled. I've opened a service request at Altera.
