Error Attempting to Back Annotate Stratix X using Quartus 21.2
Did you set any back annotate assignments? I don't see any, that could be why you get an error.
Also, it is better to use tcl commands on system command prompt outside of the Quartus GUI. Some commands are different on the tcl console of Quartus GUI vs command line/tcl scripts and some packages aren't available on tcl console of the GUI. Plus there are more references/sources with good examples on how to use tcl commands on system command prompt outside of Quartus GUI.
Nurina
- Nurina4 years ago
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
