11 years agoError 45
Hi
I'm using Quartus II to program a non-volatile security key (.ekp file) into an FPGA. However I keep getting this error message - Info: Ended Programmer operation at Mon Nov 17 15:03:01 2014 Info: Started Programmer operation at Mon Nov 17 15:04:48 2014 Info: Device 1 contains JTAG ID code 0x020E10DD Info: Programming device 1 Info: Programming the EP2SGX30 device at position 1 for exclusive-secure bitstream configuration Error: Unexpected error in JTAG server -- error code 45 Error: Operation failed Info: Ended Programmer operation at Mon Nov 17 15:04:49 2014 I'm using an Ethernet Blaster II. Does anyone know what error 45 is or what I might be doing? Thanks in advance.2 Replies
I am getting the very same error message : unexpected error in jtag server -- error code 45 when trying to program a non-volatile key (.ekp) into a Stratix II. The JTAG chain is well detected. The Ethernet Blaster II's firmware is up-to-date (April 2016). No problem when programming the external flash (.jic) Also, programming the .ekp with a former Ethernet Blaster (not II) works flawlessly ! - Altera_Forum
--- Quote Start --- Hello, I am getting the very same error message : unexpected error in jtag server -- error code 45 when trying to program a non-volatile key (.ekp) into a Stratix II. The JTAG chain is well detected. The Ethernet Blaster II's firmware is up-to-date (April 2016). No problem when programming the external flash (.jic) Also, programming the .ekp with a former Ethernet Blaster (not II) works flawlessly ! --- Quote End --- ----------------------------------------------------------------------------------- After I posted my original post I did find a solution. It a long time ago but from what I remember, it was due to incompatible programmer firmware & hardware combination. I think I had to reinstall the application as well.
