9 years agoError 332000 when using DCFIFOs in Qsys during build
I received this error message in Quartus Prime Lite 16.1 when attempting to add a dual-clock FIFO to Qsys on a DE2i-150 example project. I tested this with the DE2i-150 PCI-E Fundamental example proj...
8 years agoHi DJ/Aidan,
I try to run the synthesis system.zip above in q17.0.2std version, I do not get any error showing up in cyclone IV. can you try using this version? If you still see error, can reattached the .qsys files? Thanks, Best regards, Kentan (This message was posted on behalf of Intel Corporation)
