9 years agoError 332000 when using DCFIFOs in Qsys during build
I received this error message in Quartus Prime Lite 16.1 when attempting to add a dual-clock FIFO to Qsys on a DE2i-150 example project. I tested this with the DE2i-150 PCI-E Fundamental example proj...
9 years agoHi DJ,
I am getting the same compile error for a different PCIe related DE2i-150 design in Quartus 17.0. Did you ever find a resolution to this? In your case did you try just deleting system_sample_fifo.sdc ? Regards, Aidan
