Suhas_P_Intel
8 years agoError (281042)
I'm building a design that works with 18.0 by downloading it to my setup. However, when I try to build it, I get the following error. Is there any way to disable IP version check? Error (281042): Y...
sstrell
8 years agoYou would think that, but Standard projects must be converted to work in Pro, and Pro projects cannot be used in Standard. The version doesn't matter. Arria 10 is the only device family where this is an issue because it's the only one supported in both Standard and Pro.
