Suhas_P_Intel
8 years agoError (281042)
I'm building a design that works with 18.0 by downloading it to my setup. However, when I try to build it, I get the following error. Is there any way to disable IP version check? Error (281042): Y...
Abe
8 years agoCheck the following link:
You may need to delete those IP and create new instances of the same IP again to resolve this issue. Although the issue with an older version of Quartus, the solution provided may work for you.
