Suhas_P_Intel
8 years agoError (281042)
I'm building a design that works with 18.0 by downloading it to my setup. However, when I try to build it, I get the following error. Is there any way to disable IP version check? Error (281042): Y...
Vicky1
8 years agoHi,
- Open 'Platform Designer' from 'Tools' option & simply generate the pll2.ip and clkbuf.ip again.
- Are you able to to edit pll2.ip and clkbuf.ip from IP components?
- provide screen shot of Error/ log window
- which quartus edition are you using?
Best Regards
Vikas Jathar
