Suhas_P_Intel
8 years agoError (281042)
I'm building a design that works with 18.0 by downloading it to my setup. However, when I try to build it, I get the following error. Is there any way to disable IP version check? Error (281042): Y...
AndyN
8 years agoIs there some reason you don't want to upgrade/rebuild the IP? Which version of Quartus did you use to create the IP in the first place?
