Error 23035
Getting following error while compiling please help:
Error (23035): Tcl error: can't read "output_pt_script": no such variable
while executing
"bsdl_msg::post_msg "" E_CANNOT_OPEN_OUTPUT_FILE $output_pt_script"
invoked from within
"if [catch { set outfile [open $output_bsdl_file w] } result] {
msg_vdebug $result
bsdl_msg::post_msg "" E_CANNOT_OPEN_OUTPUT_FILE $out..."
(procedure "bsdl_generate::generate_bsdl_file" line 28)
invoked from within
"bsdl_generate::generate_bsdl_file $output_bsdl_file $device_info_list $operation"
(procedure "main" line 98)
invoked from within
"main"
(file "c:/intelfpga_lite/20.1/quartus/common/tcl/internal/eda_bsd/bsdl_main.tcl" line 288)
invoked from within
"source c:/intelfpga_lite/20.1/quartus/common/tcl/internal/eda_bsd/bsdl_main.tcl"
Error (199058): Fail to evaluate Tcl command source c:/intelfpga_lite/20.1/quartus/common/tcl/internal/eda_bsd/bsdl_main.tcl
Error: Quartus Prime EDA Netlist Writer was unsuccessful. 2 errors, 6 warnings
- ShengN_altera
Hi sidd,
Looks like the errors occurred due to Error (199058).
Have you check that path of bsdl_main.tcl is properly set or is the bsdl_main.tcl file missing?
Below attached bsdl_main.tcl file of Quartus Lite 20.1 just in case you need it.
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos. - ShengN_altera
Hi sidd,
I’m glad that the solution is helpful to you.
I now transition this thread to community support.
If you have more questions, feel free to open a new thread to get the support from Intel experts.
Thank you.
Sheng
