8 years agoError (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini Info (125061): Changed top-level design entity name ...
8 years agoThat is pretty normal, the placement and routing process is very memory intensive. Altera recommend 18-48 GB memory for Arria 10. The bigger your design is, the more memory it will need. I have seen the process taking up over 40 GB memory.
