8 years agoError (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini Info (125061): Changed top-level design entity name ...
8 years agoHi HRZ,
The fitting that was successful was the base fitting, there are supposed to be two fitting (top and base), you can check it in your compiled kernel designs, there are supposed to be 2 lines of "Quartus Prime Fitter was successful." and I only have one
